ESP
Re: ESP
Hello! I come from Finland and I would like to deactivate ESP on my 2011 Golf R DSG. However, my car has an AT ABS pump. Does anyone know instructions for the AT pump? Many thanks in advance and sorry that I have to write here in English.
ESP
Lemonator, give me coding from your ABS and I will tell you how change coding.
It will be one option from this post:
viewtopic.php?p=6723226#p6723226" onclick="window.open(this.href);return false;
ESP
You have 3D coding in byte 16, it should be two stage turning off activated. If you hold button for 5 seconds and icon isn't turned on, only blinking, try to change coding to 2D.
ESP
1 6 D, a co w momencie kiedy mam pomp\e MK60EC1 z końcówką BE i nie mam bit 3? Może ktoś jakoś pomóc aby dało się 2 stopniowo wyłączyć kontrolę?
aktualne kodowanie pompy jest takie:143B800D09220000281401E690210041390000
Będę bardzo wdzięczny za wszelaką pomoc.
pozdrawiam
pozdrawiam
