Nie daj się oszukać, sprawdź VIN i historię
WAUZZZ8LZ1A055700 Z Gory dzieki. najbardziej zalezy mi na dokladnej dacie produkcji
- grzechu590
Re: Nie daj się oszukać, sprawdź VIN i historię
Witam serdecznie
Czy moglibyście sprawdzic ten samochód w miarę szybko ( historia ,przebieg i wszystko inne... ) VW Golf V
Nr. VIN
WVWZZZ1KZ7B075286
Dziękuje bardzo:))
Nr. VIN
WVWZZZ1KZ7B075286
Dziękuje bardzo:))
Możesz byc miły, kochany, słodki i uroczy ale i tak liczba ludzi na twoim pogrzebie zależy od pogody:))
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ2W433126
Model Designation golf tdi
Date of production 20.11.2001
Model year 2002
Sales type 1J1388
Engine code ASZ
Transmission code FGA
Axle drive 5A
Interior trim code RE
Roof color 8E
Exterior color / Paint Code 8E / A7W
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2YJ Winter tires 195/65 R15 91T with steel wheel 6J x 15, with full wheel cover
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Air duct, front area VK0 Air duct, standard
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FB Automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H9 Backrest release for front seats with "Easy Entry"
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JC Comfort bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C1 Static lap belt, center rear
Chrome work package QJ0 Without aluminum/chrome work package
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M6 Cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YR Door pockets with insert mats
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A8F Sports equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor coverings 3MH Dilours floor covering w/o scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WA Without front fog light
Front license plate carrier 6W1 License plate carrier front (large)
Front stabilizer 0AE Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F9 Cooled fuel system for diesel engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R0 Selector lever cover
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C23 Operating permit, alteration
Generators 8GD Alternator 90A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X1 Headlight washer system
Headlight-range adjustment 8Q2 Automatic headlight-range adjustment static
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RB Ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Installation differentiation for vehicle components 0EQ Installation differentiation for transmission AG5 vehicle components
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 1DG Nameplate set "TDI"
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Owner's manuals 0VA Without information kit
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KG Radiator grille
Radios 8AD Radio "gamma"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q1 Rear headrests
Rear license plate carrier 6P1 License plate carrier rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BB Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N2P Fabric seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption, chassis, front G72 Front shock absorption
Shock absorption, chassis, rear UB1 Rear shock absorption for sports design
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Steering 1N1 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Telephone/telematics 9W8 Car phone preparation
Throttle actuation 0L2 Electric throttle actuation
Tires H6U Tires 205/55 R16 91W
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0F 5-speed automatic transmission
Transmission types/gearshift mechanisms 0G7 Tiptronic
Tray 7N0 Without tray on roof liner
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L08 Suspension range 08 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1NL Covers for alloy wheels
Wheels C3K Cast alloy wheels 6.5J x 16 BBS, one-piece, offset 42
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PH6
PJ9
PSF
PTS
PXE
Child seats QA0 Without child seat
Front seats Q4P Sports front seats
Nameplates for sales name QD1 Nameplates for sales name
Service interval prolongation QG1 Service interval prolongation
RCA
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Control number (no PR-Family) SA0 Model year change calendar week 45
Tire suppliers V0A Tires w/o specification of tire brand
WE1 Kod: Zaznacz cały
Vehicle Identification No. WAUZZZ8LZ1A055700
Model Designation audi a3 1.9 tdi
Date of production 21.12.2000
Model year 2001
Sales type 8L1BGC
Engine code ASZ
Transmission code DRW
Axle drive 6S
Interior trim code EK
Roof color 4J
Exterior color / Paint Code 4J / Y7R
Additional tires (winter tires) 2WA Without additional tires
Anti-theft protection system 7AA Electronic vehicle immobilization device
Backrest release 3H6 Backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
Brake type, front 1LE Disc brakes, front
Brake type, rear 1KK Disc brakes, rear
Bumper 2JB Standard bumpers
Carrier frequency for radio remote control 5D0 Without carrier frequency
Catalytic converter control 8KA W/o catalytic converter warning light
Components with special surface appearance 6FB Body-colored exterior mirror housings
Customized installation FC0 Without customized installation
Delivery equipment 2A5 Delivery equipment (transit coating) with thin seat cover
Door and lid locking system 4F1 Central locking system
Doors 0A1 2 doors
Equipment levels A9D "Ambition" equipment
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
First aid kit / warning triangle 1T3 First aid kit with warning triangle
Front fog light/additional headlight 8WB Front fog lights
Front license plate carrier 6W5 Front license plate carrier
Front stabilizer 0AL Front stabilizer
Gearshift boot/cover 6R2 Leather gearshift boot
General operating permit, alterations C15 Operating permit, alteration
Generators 8GL Alternator 120 A
Hand brake lever handle 6PA Plastic hand brake lever handle
Handling standard production and pre-production series FA0 Control of standard production
Headlight 8JH Ellipsoidal headlight for driving on the right
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated door lock cylinder 9X6 Heated door lock cylinder left with micro switch
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G8 Filler neck module 2 without insert
Inserts 5TC Without decorative inserts
Label for central electric 0W1 Label for central electric German-speaking countries
Label for radio remote control 7CA Without label for radio remote control
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Owner's manuals 0VC Information kit in German
Platform group class 7PE Platform group class 5
Radios 8UC Radio "chorus"
Rear seats 3NC Rear seat bench/backrest, split folding
Rear spoiler 5J0 Without rear spoiler
Rear trim panel 6V1 Rear trim panel (ECE)
Right exterior mirror 5RU Right exterior mirror: convex (large viewing field)
Safety certificate 0LW Special plates/stickers/ safety certificates for Germany
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat covering N0E Woven fabric seat covering
Self-collection / special control A00 No self-collection
Shock absorption, chassis, front G03 Front shock absorption
Shock absorption, chassis, rear 1JK Rear shock absorption, sports design
Sill top/sill cover 5E1 Without sill top with door cover
Spare wheel/breakdown set 1G3 Alloy spare wheel with original equipment tires
Speaker installation 9VD Speaker (active)
Special labels/plates 0ST Labels/plates in German and French
Steering 1N6 Power steering
Steering wheels 2PV Leather trimmed sports steering wheel
Tachograph/logbook 9NX Without electronic logbook
Telephone/telematics 9W0 W/o car phone preparation/installation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H6S Tires 195/65 R15 V
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Type approval countries/countries with special requirements B99 Type approval EC
Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components 0CJ Vehicle class differentiation 8L0
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L21 Suspension range 21 installation control only, no requirement forecast
Wheels CE7 Alloy wheels 7.5J x 17
Window regulator 4R1 Power windows
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
PH5
PW1
Front seats Q1D Sports front seats
Light package (lighting) QQ0 Without add. lights (interior lighting)
RBL
Instrument inserts U2A Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
Tire suppliers V0A Tires w/o specification of tire brand Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ7B075286
Model Designation golf 1.9
Date of production 17.10.2006
Model year 2007
Sales type 1K1011
Engine code BXF
Transmission code JCR
Axle drive 5S
Interior trim code HB
Roof color D3
Exterior color / Paint Code D3 / A5G
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Additional warning lights 9TC Additional reflectors (door area)
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Anti-theft protection system 7AR Electronic vehicle immobilization device with alarm system and backup horn
Backrest release 3H0 Without backrest release for front seats
Batteries J0N Battery 330 A (61 Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Brake type, front 1ZM Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Center armrest 6E0 Without center armrest front
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Climatic zones 0Y1 Standard climatic zones
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Components with special surface appearance 6FA Components without special surface appearance
Cruise control 8T2 Cruise control system (CCS) electronic
Delivery equipment 2A0 Without delivery equipment
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Drawers under front seats QN0 Without drawers under front seats
Emission standard 0GG Emission standard EU4
Engine specifications MF7 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI pump-jet injection system Base engine is T1T/T71/TG0
Equipment levels A8B Basic equipment
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
First aid kit / warning triangle 1T2 Warning triangle
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WD Integrated front fog light
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Front stabilizer 0AD Front stabilizer
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C17 Operating permit, alteration
Generators 8GU Alternator 140 A
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headrests 3J1 Height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Horns 8Y0 Single-tone horn
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Interior light in foot area 6T0 Without interior light in footwell
Left vanity mirror 4SB Vanity mirror left
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Protective side molding 4B1 Protective side molding
Radios 8YL Radio with CD player
Reading light 8S1 Reading light front
Rear headrests 3T2 Three rear headrests
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Rear stabilizer 0BD Rear stabilizer
Refrigerator 1W2 Glove compartment cooling system
Right vanity mirror 4TB Vanity mirror right
Safety headrest system 3K0 Without safety headrest system
Scuff plates 7M5 Without protective film for scuff plate
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N4C Fabric seat covering
Shock absorption, chassis, front G02 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B0 Without socket
Spare wheel/breakdown set 1G8 Breakdown set
Special labels/plates 2KW Labels/plates in German, French, and Dutch
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering wheels 1ME Steering wheel
Tire pressure warning light 7K0 Without tire pressure warning light
Tires H7F Tires 195/65 R15 91H
Tool kit and jack 1S1 Tool kit and jack
Transmission specifications G0C 5-speed manual transmission
Trunk sill protection 2P1 Plastic trunk sill protection
Vehicle class differentiation units/platform components 0HA Vehicle class differentiation 1K0/5K0
Weight category front axle L07 Suspension range 07 installation control only, no requirement forecast
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C8V Steel wheels 6J x 15
Window regulator 4R5 Power windows with comfort operation and circuit breaker, mechanical window regulators rear
RCC
Base engine T71 4-cylinder diesel engine 1.9 L unit 03G.1
Control number (no PR-Family) S5M Mobility package for Trendline
Electric interface for external use UF0 Without electric interface
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Instrument inserts U5A Instrument insert, km/h speedometer
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
W4A
WP1 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
chce kupić auto gość mówi że ma 110km i silnik afn przebieg 220tyś prosze o historie nr VIN wauzzz8dz1a037432
Proszę o sprawdzenie numeru WIN WVWZZZ1KZAP038170
Dziękuję.
Dziękuję.
Kod: Zaznacz cały
Vehicle Identification No. WAUZZZ8DZ1A037432
Model Designation audi a4 av. 1.9 tdi
Date of production 24.07.2000
Model year 2001
Sales type 8D50Z4
Engine code AHH
Transmission code EAB
Axle drive 5S
Interior trim code BR
Roof color Q5
Exterior color / Paint Code Q5 / Z5L
Alternative drive module 0K0 Without alternative drive module
Anti-theft protection system 9V7 Electronic vehicle immobilization device with anti-theft alarm system and passenger compartment control
Audio-response system/voice control QH0 Without voice control
Base engine T0E 4-cylinder diesel engine 1.9 L unit 028.U
Batteries J0R Battery 380 A (80 Ah)
Body style K8D Station Wagon Variant/Avant
Brake type, front 1LZ Front disc brakes, standard ventilation
Braking systems 1AC Anti-lock brake system (ABS)
Bumper systems 2K1 Reinforced bumpers
Color of dashboard/door and side trim panel 6RA Dashboard and door trim panel one-piece, single color
Cruise control 8T1 Cruise control system (CCS)
Dashboard 4N0 Standard dashboard
Door and lid locking system 4K4 Radio remote controlled central locking
Double-size standard radio/dual-view display 2T0 Without double-sized standard (DIN)
Engine cooling system 8Z6 Hot country
Engine specifications MQ9 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection, EU 3D base engine is T0E
Equipment levels A8S Standard equipment
Front seats Q1A Standard front seats
Fuel quantity for initial filling 1Z1 Increase in initial standard fuel filling
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Inserts 5MY Decorative inserts
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Instrument inserts U1A Instrument insert with km/h speedometer, clock, tachometer and trip odometer
Luggage compartment lining 5A5 Trunk lining, with stowage trays
Moldings 4ZB Bright moldings
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VH Information kit in Dutch
Paint preservative/transit coating 5K1 Paint preservative (wax)
Radios 8YU Radio preparation for commercial goods
Reading light 8S4 Two reading lights front, two rear
Rear headrests 3Q6 Three rear headrests
Roof rails/roof load rack 3S1 Bright roof rails
Safety certificate 0LY Special plates/stickers/ safety certificates for the Netherlands
Scuff plates 7M1 Scuff plates in door apertures with metal inserts
Seat covering N5F Fabric seat covering
Seat heater 4A0 Without seat heater
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Special labels/plates 0SZ Labels/plates in Dutch and French
Steering wheels 1MR Leather steering wheel
Tires H6R Tires 195/65 R15 T
Transmission shafts 1WD Transmission shaft for tripod joints
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Vehicle class differentiation units/platform components 0DY Installation differentiation for build status of vehicle class B5 (AUDI) unit components
Weight category front axle 0JF Weight category front axle weight range 6
Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
Wheels C8N Alloy wheels 7.5J x 18
Window regulator 4R2 Power windows front, mechanical window regulators rear
WFK
WM3 Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZAP038170
Model Designation golf 1.4
Date of production 20.08.2009
Model year 2010
Sales type 5K13G2
Engine code CAXA
Transmission code MCB
Axle drive 6S
Interior trim code FW
Roof color 7B
Exterior color / Paint Code 7B / R7L
"Charism" 2H0 Without "drive select"
"Multimedia", video/DVD/notebook connection 9WL Multimedia socket for external audio source
Activated carbon canister 1E1 Activated carbon canister
Air bag 4UP Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
Batteries J1L Battery 280 A (60 Ah)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Doors 0A2 4 doors
Emission standard 7MG Emission standard EU5
Engine specifications D4X 4-cylinder SI engine 1.4 l/90 KW TSI base engine is TU0/TL1/TM5
Equipment levels A8C Comfort equipment
Exhaust tailpipe 0P1 Rear side exhaust tailpipe
Exterior mirror setting 6XG Exterior mirrors: with memory function, electrically adjustable/heated
Front seat, left 3TF Comfort seat, front left
Front seat, right 3SF Comfort seat, front right
Fuel systems 1A5 Fuel system for fuel-injected engine
General operating permit, alterations C31 Operating permit, alteration
Headlight activation 8K3 Separate daytime running lights with low beam assistant and "Coming Home" feature
Headlight-range adjustment 8Q4 Headlamp range adjustment with fixed bending light
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MB Decorative inserts
Interior light in foot area 6T1 Interior light in footwell
Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 3U4 Luggage compartment cover
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Multi-function display/trip computer 9Q5 Multi-function display with control
Nameplate set 0NW Nameplate set "TSI"
Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
Park distance control 7X5 Parallel parking assistant
Radiator grille 6KC Radiator grille
Radios 8AE Radio "RCD310 MP3"
Rear seats 3NU Rear seat bench unsplit, backrest split folding with center armrest
Seat covering N3B Fabric seat covering
Shock absorption, chassis, front G07 Front shock absorption
Side and rear windows 4KF Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
Start/stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
Steering wheels 1MV Leather steering wheel
Tires HH7 Tires 205/55 R16 91V
Tool kit and jack 1S3 Tool kit
Upgrading measures GP1 Vehicles with special upgrade measures
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
Wheels CM5 Alloy wheels 6.5J x 16
Windshield wiper intermittent control 8N3 Windshield wiper intermittent control with rain sensor
PAA
PH2
PJ1
PLA
PNS
Chrome work package QJ1 Chrome work package
Drawers under front seats QN3 Drawers under front seats
RGC
Base engine TU0 4-cylinder gasoline engine 1.4 L unit 03C.K
Marten repeller UM0 Without marten repeller
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam,
bardzo proszę o rozkodowanie VINu
WVWZZZ1KZ5W240934
Golf mk5
WVWZZZ1KZ5W240934
Golf mk5
Witam,
WVWZZZ1KZ5W180514
Golf mk5
WVWZZZ1KZ5W180514
Golf mk5
Fircyk123456
Witam wszystkich serdecznie!
Bardzo proszę o rozkodowanie vin
WVWZZZ1KZ6W143024
Golf 5
Z góry dziękuję
WVWZZZ1KZ6W143024
Golf 5
Z góry dziękuję
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ5W240934
Date of production 27.04.2005
Model year 2005
Sales type 1K1111
Engine code BRU
Transmission code GQQ
Axle drive 5S
Interior trim code JS
Roof color A1
Exterior color / Paint Code A1 / 041
Brake type, front 1ZF Disc brakes, front (Geomet D)
Doors 0A2 4 doors
General operating permit, alterations C09 Operating permit, alteration
Glove compartment 4Z3 Lockable glove compartment door, with light
Heated washer nozzles 9T0 Without heated washer nozzles
Left vanity mirror 4SG Left vanity mirror illuminated extractable sun visor
Luggage compartment cover 3U3 Luggage compartment cover with luggage net
Right vanity mirror 4TG Right vanity mirror illuminated extractable sun visor
Safety headrest system 3K1 Safety headrest system
Seat covering N0U Cut pile seat covering
Speaker installation 8RL 6 speakers (passive)
Steering wheels 1MA Steering wheel
Wheels CM2 Alloy wheels 6.5J x 15
PH2
RAB
Vehicle Identification No. WVWZZZ1KZ5W180514
Date of production 07.01.2005
Model year 2005
Sales type 1K1131
Engine code BKC
Axle drive 5S
Roof color 8E
Doors 0A2 4 doors
Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
General operating permit, alterations C08 Operating permit, alteration
PH2
RAB
Control number (no PR-Family) S13 United w/o multi-function steering wheel
W4B
WW1 Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ6W143024
Date of production 16.02.2006
Model year 2006
Sales type 1K1011
Engine code BRU
Axle drive 5S
Interior trim code HA
Roof color A1
Antennas 8ZN Antenna
Control number (no PR-Family) S0Z Control (in-plant)
Doors 0A1 2 doors
General operating permit, alterations C14 Operating permit, alteration
Heating and air conditioning system 9AA Manually controlled heating system
Owner's manuals 0VT Information kit in Polish
Radios 8AA Without radio
Refrigerator 1W0 Without refrigerator/glove compartment cooling system
Speaker installation 8RE 4 speakers (passive)
Type approval countries/countries with special requirements B17 Type approval Poland
Weight category rear axle 0YA Weight range 1 installation control only, no requirement forecast
PR3
Hello
Mam pilny temat, bo dzisiaj wieczorem lecę na wakacje a trafił mi sie dupovwóz mk5 od pierwszego własciciela i potrzebuję go sprawdzić dzisiaj do popołudnia (18:00). Auto miało podobno wymieniony cały silnik na gwarancji - ma ktoś mozliwosc sprawdzenia historię serwisu?
VIN: WVWZZZ1KZ9P011860
Z góry dziękuję
Z góry dziękuję
Jeśli można to i ja proszę o rozkodowanie vin'u audi a4 WAUZZZ8E94A170467
