Błędy kto przetłumaczy na ludzki język
VAG-COM Version: Release 311.2-N
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01 -------------------------------------------------------
Controller: 4B0 907 552 C
Component: 2.4L V6/5V MOTR HS D03
Coding: 04102
Shop #: WSC 02325
7 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-10 - - - Intermittent
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-10 - - - Intermittent
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 C
Component: ABS/ASR 5.3 FRONT D00
Coding: 00000
Shop #: WSC 02325
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 G
Component: A6-K
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 4B0 959 655 G
Component: Airbag Front+Seite 0001
Coding: 00106
Shop #: WSC 00000
Address 17 -------------------------------------------------------
Controller: 4B0 919 860 F
Component: C5-KOMBIINSTR. VDO D09
Coding: 01162
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0W0630832
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End -------------------------------------------------------
Chcę nabyć auto ale ma takie błędy czy to coś poważnego ??
Coding: 04102
Shop #: WSC 02325
7 Faults Found:
P1127 - 35-00 - -
Readiness: N/A
Coding: 00000
Shop #: WSC 02325
Component: A6-K
Coding: 00106
Shop #: WSC 00000
Coding: 01162
Shop #: WSC 00000
No Faults Found
Większość tych błędów mogą być spowodowane poprzez montaz instalacji gazowej.Pierwszy błąd może oznaczać jakąś awarie alternatora np.regulator napięcia.Te v-ki jeżdzą ładnie na sekwencji ale błędy na kompach się pojawiają od gazu.Spróbuj wykasować błędy i odpal na benzynie wykonaj jazdę próbną nie włączając LPG.Mile widziany raport z tej operacji
badz taki mily i napisz co bylo, komus sie moze sprzydac napewno.
[img]http://img526.imageshack.us/img526/3653/vwban2jq9gi6.jpg[/img]
Więc uszkodzone były obie sondy lambda, pompa paliwa, oraz przepływomierz... te 3 usterki to główne które udało mi się ustalić a że właściciel nie chciał spuścić ceny na części to odpuściłem sobie zakup tego samochodu
