Nie daj się oszukać, sprawdź VIN i historię
Moderatorzy: palio, jhosef, VIP
Witam prosiłbym o sprawdzenie numeru
WVWZZZ1JZXW443788
Z góry dzięki !
WVWZZZ1JZXW443788
Z góry dzięki !
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZXW443788
Model Designation golf tdi
Date of production 28.11.1998
Model year 1999
Sales type 1J1234
Engine code ALH
Transmission code DQY
Axle drive 5S
Interior trim code EM
Roof color D8
Exterior color / Paint Code D8 / P3G
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H3 Backrest release for front seat(s)
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1LS Front disc brakes with integrated adapter
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E0 Without center armrest front
Center rear seat belts 3C1 Static lap belt, center rear
Chassis 2E0 Base chassis
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M5 Cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications MD1 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI base engine is T0W/T0E
Equipment levels A8C Comfort equipment
Exterior mirror setting 6XB Exterior mirrors: adjustable from inside
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Flame retardent materials 4Q1 Flame retardent materials
Floor mats 0TA Without floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AM Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F3 Fuel system for diesel engine
Fuel tank treatment 2LA Fuel tank without special material treatment
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C07 Operating permit, alteration
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8JS Twin headlight for driving on the right with clear lens
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AA Manually controlled heating system
Horns 8Y0 Single-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Key for locking system 8QE Key for locking system with remote control
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2QK Nameplate set "TDI"
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B1 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8AA Without radio
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q1 Rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NB Rear seat bench/backrest, completely folding
Rear stabilizer 0BC Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat belt check 9P0 Without seat belt reminder
Seat covering N4C Fabric seat covering
Seat heater 4A0 Without seat heater
Shock absorption, chassis, front 1GC Front shock absorption, basic design 3
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 8F2 Side turn signal lights
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RA Without speakers
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 1MP Steering wheel for air bag system
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H6R Tires 195/65 R15 T
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Trunk sill protection 2P0 Without trunk sill protection
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1ND Full wheel covers
Wheels C6E Steel wheels 6J x 15 Offset 38
Window regulator 4R0 Mechanical window regulator
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PT1
PTA
Base engine T0W 4-cylinder diesel engine 1.9 L unit 038.B
Front seats Q1A Standard front seats
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Service interval prolongation QG0 Without service interval prolongation
Tire suppliers V0A Tires w/o specification of tire brand
Weight category front axle U27 Suspension range 126 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Re: Nie daj się oszukać, sprawdź VIN i historię
Witam, bardzo prosze o sprawdzenie nr VIN
WAUZZZ8DZWA058388
WAUZZZ8DZWA058388
Kod: Zaznacz cały
Vehicle Identification No. WAUZZZ8DZWA058388
Model Designation audi a4 1.8
Date of production 28.10.1997
Model year 1998
Sales type 8D20C4
Engine code ADR
Transmission code
Axle drive
Interior trim code BR
Roof color Q8
Exterior color / Paint Code Q8 / Y5L
Activated carbon canister 1E1 Activated carbon canister
Alternative drive module 0K0 Without alternative drive module
Anti-theft protection system 7AA Electronic vehicle immobilization device
Batteries J1P Battery 220 A (44 Ah)
Body style K8B Notchback
Brake type, front 1LZ Front disc brakes, standard ventilation
Braking systems 1AH Electronic differential lock (EDL)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper systems 2K1 Reinforced bumpers
Carrier frequency for radio remote control 5D0 Without carrier frequency
Catalytic converter control 8KA W/o catalytic converter warning light
Center armrest 6E3 Front center armrest
Center high-mounted stop light 8R1 Center high-mounted stop light
Color of dashboard/door and side trim panel 6RA Dashboard and door trim panel one-piece, single color
Cruise control 8T1 Cruise control system (CCS)
Cup holder 4M6 Cup holder
Delivery equipment 2A5 Delivery equipment (transit coating) with thin seat cover
Door and lid locking system 4F1 Central locking system
Engine specifications M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
Equipment levels A8S Standard equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B0 Without additional exterior noise suppression
First aid kit / warning triangle 1T2 Warning triangle
Floor mats 0TC Front floor mats
Front license plate bracket 6W5 Front license plate bracket
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C06 Operating permit, alteration
Generators 8GD Alternator 90A
Handling standard production and pre-production series FA0 Control of standard production
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headlight washer system 8X1 Headlight washer system
Heated door lock cylinder 9X6 Heated door lock cylinder left with micro switch
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
Inserts 5MF Decorative aluminum inserts
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Label for radio remote control 7CA Without label for radio remote control
Left vanity mirror 4SB Vanity mirror left
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Moldings 4ZE Black moldings
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VC Information kit in German
Radios 8UC Radio "chorus"
Reading light 8S4 Two reading lights front, two rear
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Rear trim panel 6V1 Rear trim panel (ECE)
Right vanity mirror 4TB Vanity mirror right
Roll-up sun screen for rear and side windows 3Y1 Roll-up sun screen for rear window
Safety certificate 1QA Special plates/stickers/ safety certificates for Austria
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat covering N4G Fabric seat coverings
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Sill top/sill cover 5E1 Without sill top with door cover
Ski bag 3X0 Without load-through provision
Spare wheel/breakdown set 1G3 Alloy spare wheel with original equipment tires
Speaker installation 8RN Sound package (brand sound)
Special labels/plates 0ST Labels/plates in German and French
Steering wheels 1MR Leather steering wheel
Tires H6S Tires 195/65 R15 V
Transmission shafts 1WC Transmission shafts w/ 108 mm in diameter
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Type approval countries/countries with special requirements B99 Type approval EC
Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components 0DY Installation differentiation for build status of vehicle class B5 (AUDI) unit components
Weight category front axle 0JE Weight category front axle weight range 5
Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
Wheels C8N Alloy wheels
Window regulator 4R2 Power windows front, mechanical window regulators rear
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
P15
PW1
Base engine T5Z 4-cylinder gasoline engine 1.8 L unit 058.B
Control number (no PR-Family) SL9 Control (in-plant)
RBL
Control number (no PR-Family) S6U Control (in-plant)
Instrument inserts U1A Instrument insert with km/h speedometer, clock, tachometer and trip odometer Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
- Majki
- Auto: Touran GP2
Prosiłbym bym o sprawdzenie numeru VIN: WVWZZZ1JZXP622288
Z góry dziękuję :0
Z góry dziękuję :0
VW Touran GP2 1.6 TDI - obecnie
Mazda 5 1.8 - EX
Seat Cordoba SX 2.0 - EX
VW Golf IV 1.8T - EX
VW Passat B4 2.8 - EX
VW Golf MK3 1.8 - EX
Ford Fiesta MK3 1.1 - EX
Mazda 5 1.8 - EX
Prosiłbym o sprawdzenie numeruWIN VWZZZ6RZAY045264
Dziękuje.
Dziękuje.
zły format vinu...volder pisze:Prosiłbym o sprawdzenie numeruWIN VWZZZ6RZAY045264
Dziękuje.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ6RZAY045264
Model Designation polo
Date of production 29.08.2009
Model year 2010
Sales type 6R12E4
Engine code CGGB
Transmission code LVE
Axle drive 5S
Interior trim code BY
Roof color A1
Exterior color / Paint Code A1 / 041
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B3 Child seat anchor
Air cleaner (engine) 1L0 Standard air cleaner
Air duct, front area VK0 Air duct, standard
Antennas 8ZG Antenna for AM/FM reception
Backrest release 3H0 Without backrest release for front seats
Battery/alternator capacity NY0 Standard battery/alternator capacity
Body measures 5C6 Additional body measures
Brake type, front 1ZG Disc brakes, front (Geomet D)
Brake type, rear 1KT Disc brakes, rear (Geomet D)
Bumper 2JF Painted bumpers
Center rear seat belts 3C7 3-point seat belt for center rear seat
Climatic zones 0Y1 Standard climatic zones
Components with special surface appearance 6FA Components without special surface appearance
Controls (steering wheels/steering column) 4LA Without controls
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M0 Without cup holder
Customized installation FC0 Without customized installation
Dashboard 4N0 Standard dashboard
Dashboard illumination 7V1 Standard dashboard illumination
Delivery equipment 2A0 Without delivery equipment
Door and side trim panels 4AP Door and side trim panel
Doors 0A2 4 doors
Drawers under front seats QN0 Without drawers under front seats
Emission standard 7MG Emission standard EU5
Engine specifications D22 4-cyl. gasoline engine 1.4 l/63 kW (16V) Base engine is TT1/TK0
Exhaust tailpipe 0P2 Exhaust tailpipe with trim
Front stabilizer 0AQ Front stabilizer
Fuel systems 1A3 Fuel system for carburetor gasoline eng. with injector system without fuel return and modified injection pressure
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C01 Operating permit, alteration
Generators 8GG Alternator 110 A
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 9I0 Dipped beam headlights as daytime running lights
Headrests 3J1 Height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Horns 8Y4 High-sounding horn
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Installation differentiation for vehicle components 0EM Installation differentiation for transmission MQ 200 vehicle components
Interior light in driver compartment 9GA Interior light with door pillar switches
Interior light in foot area 6T0 Without interior light in footwell
Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
Left vanity mirror 4SC Left vanity mirror with cover
Luggage compartment lining 5A6 Full fleece trunk lining
Manufacturing sequence differentiation 0FB Pamplona manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Molding roof liner 6NA Unsplit molding roof liner
Nameplate set 0QK Nameplate set "1.4"
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Owner's manuals 0VT Information kit in Polish
Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P2 Rear floor panel module, type 3
Radiator grille 6KA Radiator grille
Radios 8UA Radio with CD player
Reading light 8S0 Without reading light
Rear axle 0N2 Heavy-duty rear axle
Rear cargo area 3GD Plane rear cargo area
Rear headrests 3Q6 Three rear headrests
Rear seats 3NC Rear seat bench/backrest, split folding
Rear stabilizer 0BA Without rear stabilizer
Refrigerator 1W2 Glove compartment cooling system
Restraint systems, front 4QV 3-point seat belts with electric tensioner and height adjustment, front
Right vanity mirror 4TC Right vanity mirror with cover
Scuff plates 7M5 Without protective film for scuff plate
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N0V Fabric seat covering
Shock absorption, chassis, front G09 Front shock absorption
Shock absorption, chassis, rear 1JP Rear shock absorption
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B2 12-volt socket in luggage boot
Speaker installation 8RE 4 speakers (passive)
Special labels/plates 0SA Without special labels/plates
Start/stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
Steering 1N2 Power steering electro-hydraulic
Steering wheels 1ME Steering wheel
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SG Standard taillight assemblies (type 2)
Tire pressure warning light 7K0 Without tire pressure warning light
Tires HK9 Tires 175/70 R14 84T
Tool kit and jack 1S1 Tool kit and jack
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B17 Type approval Poland
Vehicle class differentiation units/platform components 0DF Vehicle class differentiation 6R0- for build status Europe
Vehicle type AZ0 Vehicle with standard production scope
Weight category front axle L37 Suspension range 37 installation control only, no requirement forecast
Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C0D Steel wheels 5J x 14
PBA
PH1
PJW
Chrome work package QJ0 Without aluminum/chrome work package
Service interval prolongation QG1 Service interval prolongation
RFA
Base engine TT1 4-cylinder gasoline engine 1.4 L unit 036.R
Electric interface for external use UF0 Without electric interface
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZXP622288
Model Designation golf gti turbo
Date of production 14.04.1999
Model year 1999
Sales type 1J16R4
Engine code AGU
Transmission code ECW
Axle drive 5S
Interior trim code RJ
Roof color 1D
Exterior color / Paint Code 1D / W5Z
Backrest release 3H8 Backrest release for front seats with "Easy Entry" and memory function
Base engine T8C 4-cylinder gasoline engine 1.8 L unit 06A.C
Batteries J1L Battery 280 A (60 Ah)
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Bumper 2JC Comfort bumpers
Component part sets with country-specific design requirements B0C Component parts set, complying with vehicle type for Belgium, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Control number (no PR-Family) ST7 Model year change, calendar week 02
Control number (no PR-Family) SX6 Control of vehicles according to change request V98K07 (hood lock)
Cruise control 8T2 Cruise control system (CCS) electronic
Door pockets, front 3YR Door pockets with insert mats
Doors 0A1 2 doors
Engine specifications MQ4 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 3D base engine is T8C
Equipment levels A8H Top sports equipment
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Floor mats 0TQ Front and rear floor mats (polypropylene)
Front fog light/additional headlight 8WD Integrated front fog light
Front stabilizer 0AL Front stabilizer
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift knob/handle 6Q3 Wooden gearshift knob/handle
General operating permit, alterations C09 Operating permit, alteration
Hand brake lever handle 6PC Leather hand brake lever handle
Heating and air conditioning system 9AB Manually controlled air conditioning
Horns 8Y1 Two-tone horn
Inserts 5MW Decorative inserts, dark myrtle wood
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U1 Luggage nets/pockets on backrests
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Nameplate set 0NH Nameplate set "GTI"
Protective side molding 4B2 Body-colored protective side molding
Rear headrests 3T3 3 rear headrests height-adjustable
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BB Rear stabilizer
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Seat adjustment 3L3 Manual height adjustment for front seats
Seat covering N2T Fabric seat covering
Shock absorption, chassis, front 1GD Front sports shock absorption
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
Side lights 8F6 Dark colored side turn signal lights
Speaker installation 8RM 8 speakers (passive)
Steering wheels 2PX Leather trimmed sports steering wheel
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Throttle actuation 0L0 Mechanical throttle actuation
Tires H6U Tires 205/55 R16 91W
Trailer hitch 1D2 Trailer hitch, removable and lockable
Type approval countries/countries with special requirements B02 Type approval Belgium
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle J65 Suspension range 65
Wheel covers 1NL Covers for alloy wheels
Wheels C7Y Alloy wheels 6.5J x 16
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
P05
P12
PH1
Front seats Q2Q RECARO sports seats, front
Prosiłbym o sprawdzenie numeru VIN
VSSZZZ1MZ1R077879
Z góry dziękuje.
VSSZZZ1MZ1R077879
Z góry dziękuje.
Kod: Zaznacz cały
Vehicle Identification No. VSSZZZ1MZ1R077879
Model Designation leon signo
Date of production 22.03.2001
Model year 2001
Sales type 1M1824
Engine code ASV
Transmission code EGS
Axle drive 5S
Interior trim code AX
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Base engine T8U 4-cylinder diesel engine 1.9 L unit 038.G
Brake pad wear indicator 9U1 Brake pad wear indicator
Braking systems 1AJ Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Bumper 2JG Body-colored bumpers
CD changer/CD player 7A1 CD changer preparation
Child seats QA0 Without child seat
Component part sets with country-specific design requirements B0V Component parts set, complying with vehicle type for the Netherlands various parts
Components with special surface appearance 6FB Body-colored exterior mirror housings
Dashboard 4N1 Padded dashboard
Doors 0A2 4 doors
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine specifications MN0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDI EU 3 base engine is T8U
Equipment levels A8W Luxury equipment
Exterior mirror setting 6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front license plate bracket 6W0 Without license plate bracket front
Front stabilizer 0AE Front stabilizer
General operating permit, alterations C12 Operating permit, alteration
Headphone port, rear 8MB Headphone port rear
Heated door lock cylinder 9X0 Without heated door lock cylinder
Heated rear window 8P1 Heated rear window
Insert for the filling up of unleaded fuel/fuel type 2G8 Filler neck module 2 without insert
Inserts 5TC Without decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Interior light in driver compartment 9GB Interior light with switch-off delay and door pillar switch
Luggage net/pocket on backrest(s) 4U3 Luggage net on backrest, right seat
Nameplate set 2VP Nameplate set "TDI" "I"
Owner's manuals 0VH Information kit in Dutch
Pillar lining 4XF Exterior pillar lining design 2
Platform group class 7PB Platform group class 2
Radios 8YE Radio for comfort-class vehicle
Reading light 8S1 Reading light front
Rear axle 0N5 Standard rear axle
Rear fog light 8TF Rear fog lights, left and right
Rear license plate bracket 6P0 Without license plate bracket rear
Rear spoiler 5J5 Body-colored rear spoiler (version 2)
Restraint systems, front 4QU 3-point seat belts front w/ tensioner (electr.) and height adjustment
Right exterior mirror 5RU Right exterior mirror: convex (large viewing field)
Rough-road/sports version 2UA Standard design
Seat covering N7C Fabric seat covering
Service interval prolongation QG2 No possibility of activating service interval prolongation
Shock absorption, chassis, front G25 Front shock absorption
Side lights 7R3 Side turn signal lights (white)
Sill top/sill cover 5E2 Sill top with door cover
Special labels/plates 0SE Labels/plates in Dutch
Steering 1N6 Power steering
Steering wheels 1MF Comfort steering wheel for air bag system
Trailer hitch 1D3 Trailer hitch
Type approval countries/countries with special requirements B31 Type approval the Netherlands
Vehicle class differentiation units/platform components 0CK Vehicle class differentiation 1M0
Weight category front axle L20 Suspension range 20 installation control only, no requirement forecast
Wheel covers 1NH Full wheel covers
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds) Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam,
Planuje kupić Tourana i mam prośbę o sprawdzenie numeru VIN
WVGZZZ1TZ6W085235 oraz jaka samochód ma historię bo sprzedawca nie posiada książki serwisowej.
Z góry wielkie dzięki
muchatp@o2.pl
muchatp@o2.pl
Poproszę o sprawdzenie WVWZZZ1JZXW559815.
Z góry dziękuje pozdr.
VIN, Jak mozna to prosilbym
sprawa zycia i smierci ze tak powiem...
WAUZZZ8LZXA114624
oraz czy oprocz wypasu, wyskoczy cos jeszcze
pzdr
WAUZZZ8LZXA114624
pzdr
ARL bez dymu nie ma ognia
https://www.youtube.com/watch?v=rtb1p9N1Oww
Mocna zdrowa seria ARL 0-100 :
https://www.youtube.com/watch?v=wE3clOC1cFU
oraz inne
oraz inne
