ESP
ESP
O ile dogada się z resztą systemu...vrs pisze:Tak sobie cały czas myślę, to musi być w sterowniku tak? To może zapodaj najnowszy sterownik i po problemie
Gdyby R-ki były dla wszystkich, to nazywałyby się GTI.
TYM JEŻDŻĘ Taki tam sobie skromny golfik w drodze do 10.xx na 1/4 mili <KLIK>
Dawaj lajka! FB.com/GolfR32Turbo
ESP
Michał, pewnie niewiele zmienili. Tylko wydaje się, że ABS/ESP śpi na tej samej płytce co wszystko. Czyli mowa o wymianie całego kompa...
ESP
Tomku czy będziesz tak miły i to sprawdzisz?
Masz ten sprytny kabelek.
I have verified that the below VAGCOM coding procedure(posted in another thread), works to disable the 2nd stage of the traction control:
"If anyone still interested, the ESP disable for the Golf 6 R can be done by the adjustment channel 9 in steering control unit (address word 44) turn to off (from 0 to 1). In this case, as it were recoded to the old power steering which the steering angle sensor had in the steering wheel. The steering angle is no longer sent to the CAN bus and the ESP control unit, this information is not longer available. Makes sense only for the track, must also be coded using a diagnostic tester back again because the adjustment even with ignition off / on will remain."
"Adjustment channel 9 put in power steering control unit to 1, ESP is permanently off. ABS and Co is retained."
So anybody with a VAG-COM feel like trying out and reporting what happens changing the value for:
- 44 "Steering Assist":......Adaptation channel 09 - Steering Angle Sensor
The car is completely transformed when this is completed. Please do this at your own risk, as the car becomes much more tail happy and WILL get sideways. You will have three lights appear solidly on the cluster when you enable the coding; bulb out, traction control, and TPMS. The TPMS light can be disabled with a separate coding.
2015 - ... Mocy przybywaj?
2010 - 2014 Golf .:R20
ESP
Ano kabelek posiadam, ale moja bateryjka jest w malowaniu...MatthewG pisze:Tomku czy będziesz tak miły i to sprawdzisz? Masz ten sprytny kabelek.
ESP
Teraz dopiero przeczytałem słowo "bateryjka". Z tym, że ja miałem na myśli MKV
Tam jest haldex drugiej generacji, ale to chyba nic nie zmienia. A może inny użytkownik forum ma eRkę i kabelek?
ESP
Znalazłem opis pewien na vwvortex odnośnie opcji dwustopniowej dezaktywacji ESP:
http://forums.vwvortex.com/showthread.p ... P-for-FREE!!!!" onclick="window.open(this.href);return false;!
ESP
jestem ciekaw czy to na 100% działa, jak coś to mam kabelek więc jak by ktos chciał spróbować to włączyć to mogę pomóc w okolicach warszawy
Jest R32
BYŁ: GOLF MKVII R 2.0 DSG 2015 STG 2
BYŁ: Audi S3 8V1 S-Tronic 2014
był: Golf R 2.0 DSG STG 3 by CS
ESP
Z tego co temat ten na szybko przeglądałem to chyba i tak nie każdy sterownik ABS z Golfa 6 to przyjmie, rok modelowy 2012 nawet w TDI przyjął, z 2011 może być ciężej.
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 42 gości
