Nie daj się oszukać, sprawdź VIN i historię
Moderatorzy: palio, jhosef, VIP
- kylu
Nie daj się oszukać, sprawdź VIN!
Proszę także o sprawdzenie nr. VIN: WVWZZZ1JZ1W716380. Z góry dzięki , pzdr.
Zobacz [b][size=117][url=http://forum.vwgolf.pl/viewtopic.php?t=90827]MK III CL Edition by kylu[/url][/size][/b] i zmień go :D
[b][url]http://www.vwdolnyslask.pl[/url][/b]
Re: Nie daj się oszukać, sprawdź VIN!
kylu pisze:Proszę także o sprawdzenie nr. VIN: WVWZZZ1JZ1W716380. Z góry dzięki , pzdr.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ1W716380
Model Designation golf tdi variant
Model GOLF
Date of production 18.04.2001
Model year 2001
Sales type 1J5114
Engine code ALH
Transmission code EGR
Axle drive 5S
Interior trim code CM
Roof color 8E
Exterior color / Paint Code 8E / A7W
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L3 Roof antenna
Anti-theft protection system 7AH Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H0 Without backrest release for front seats
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8D Station Wagon Variant/Avant
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1LS Front disc brakes with integrated adapter
Brake type, rear 1KP Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A3 CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C1 Static lap belt, center rear
Chrome work package QJ0 Without aluminum/chrome work package
Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M6 Cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AR Door and side trim panel in foam film and circular-knit
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine guard 1SA Without additional engine guard
Engine specifications MD1 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI base engine is T0W/T0E
Equipment levels A8C Comfort equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T2 Warning triangle
Floor coverings 3MF Dilours floor covering with scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AE Front stabilizer
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Fuel systems 0F3 Fuel system for diesel engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C19 Operating permit, alteration
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8JU Twin headlight for driving on the left with clear lens
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AB Manually controlled air conditioning
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Left exterior mirror 5SJ Left exterior mirror: convex
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U2 Sliding trunk cover
Luggage compartment floor covering 6SL Tufted trunk floor covering (cut pile)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2QK Nameplate set "TDI"
Nameplates for sales name QD1 Nameplates for sales name
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P3 Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B1 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8AD Radio "gamma"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GN Variable cargo area concept
Rear fog light 8TD Rear fog light for driving on the left
Rear headrests 3Q1 Rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NE Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BC Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RV Right exterior mirror: aspherical
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S2 Black roof rails
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N0U Cut pile seat covering
Seat heater 4A0 Without seat heater
Service interval prolongation QG1 Service interval prolongation
Shock absorption, chassis, front G09 Front shock absorption
Shock absorption, chassis, rear 1JH Rear shock absorption
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SC Labels/plates in English
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0R Right-hand drive vehicle
Steering wheels 1MP Steering wheel for air bag system
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tires H6R Tires 195/65 R15 T
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Tray 7N0 Without tray on roof liner
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B09 Type approval Great Britain and Northern Ireland
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L20 Suspension range 20 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1ND Full wheel covers
Wheels C6E Steel wheels 6J x 15 Offset 38
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PH3
Child seats QA0 Without child seat
Front seats Q2J Comfort front seats
RCA
Air duct, front area VK0 Air duct, standard
Base engine T0W 4-cylinder diesel engine 1.9 L unit 038.B
Instrument inserts U0L Instrument insert with tachometer clock and mph speedometer
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
- czarnykurczak
- _
Poproszę o sprawdzenie: WVWZZZ1JZWD116007
Czy na podstawie VIN da się ustalić czy ten samochód ma dwumasowe koło zamachowe?
Pozdrawiam.
Pozdrawiam.
Proszę o sprawdzenie WVWZZZ3BZWE077014 . Z góry dziękuje.
Był Golf MK3 Variant (skasowany) jest Passat B5 1,9 Tdi
Wydaję mi się, że wszystkie TDI w MK4 miały dwumasy, ale mogę się mylić...czarnykurczak pisze:Poproszę o sprawdzenie: WVWZZZ1JZWD116007
Pozdrawiam.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZWD116007
Model GOLF
Date of production 04.05.1998
Model year 1998
Sales type 1J1244
Engine code AGR
Transmission code DQY
Axle drive 5S
Interior trim code EL
Roof color G9
Exterior color / Paint Code G9 / C3K
Anti-theft protection system 7AA Electronic vehicle immobilization device
Body style K8G Hatchback
Brake type, rear 1KK Disc brakes, rear
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D0 Without carrier frequency
Catalytic converter control 8KA W/o catalytic converter warning light
Center armrest 6E0 Without center armrest front
Chassis 2E0 Base chassis
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M5 Cup holder
Dashboard illumination 7V0 Standard dashboard illumination
Door and lid locking system 4F1 Central locking system
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Engine specifications M0G 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI with MVEG 2 base engine is T0W
Exterior mirror setting 6XB Exterior mirrors: adjustable from inside
Flame retardent materials 4Q0 No flame retardent materials
Floor mats 0TA Without floor mats
Front stabilizer 0AM Front stabilizer
Fuel tank treatment 2LA Fuel tank without special material treatment
General operating permit, alterations C03 Operating permit, alteration
Generators 8GM Alternator 70 A
Headlight 8JS Twin headlight for driving on the right with clear lens
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heating and air conditioning system 9AA Manually controlled heating system
Horns 8Y0 Single-tone horn
Interference suppression 8E0 Without interference suppression
Key for locking system 8QC Key with light
Label for radio remote control 7CA Without label for radio remote control
Left exterior mirror 5SL Left exterior mirror: aspherical
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Manufacturing sequence differentiation 0FK Bratislava manufacturing sequence
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Radios 8AA Without radio
Rear axle 0N1 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q0 Without rear headrests
Rear seats 3NB Rear seat bench/backrest, completely folding
Right exterior mirror 5RQ Right exterior mirror: convex
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat covering N4C Fabric seat covering
Shock absorption, chassis, front 1GC Front shock absorption, basic design 3
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X0 Without side air bag
Side lights 8F2 Side turn signal lights
Socket 7B0 Without socket
Speaker installation 8RE 4 speakers (passive)
Special labels/plates 0SE Labels/plates in Dutch
Steering system arrangement L0L Left-hand drive vehicle
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Type approval countries/countries with special requirements B31 Type approval the Netherlands
Window regulator 4R0 Mechanical window regulator
PTB
Control number (no PR-Family) S34 Data logger line for special device connection (e.g. head unit MMI 3G)
Front seats Q1A Standard front seats
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Weight category front axle U28 Suspension range 127 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
slawekma pisze:Proszę o sprawdzenie WVWZZZ3BZWE077014 . Z góry dziękuje.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ3BZWE077014
Model Designation passat estate
Model PA
Date of production 17.07.1997
Model year 1998
Sales type 3B5358
Engine code AFN
Transmission code DMX
Axle drive 4A
Interior trim code FC
Roof color G2
Exterior color / Paint Code G2 / Y3D
Additional body covers, side 6EP Additional stone guard body covers
Alternative drive module 0K0 Without alternative drive module
Automatic transmission indicator light 9FB Automatic transmission indicator light
Batteries J0R Battery 380 A (80 Ah)
Brake type, front 1LB Disc brakes, front
Center high-mounted stop light 8R1 Center high-mounted stop light
Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
Climatic zones 0Y1 Standard climatic zones
Door and side trim panels 3LC Door and side trim panel in foam film and woven fabric
Duty-free tires 1V0 Without duty-free and cost-free tires
Engine specifications M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDI with MVEG 2 base engine is T1R
Equipment levels A8S Standard equipment
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Floor coverings 3MQ Ibolours floor covering
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Gearshift boot/cover 6R0 Selector lever cover
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C04 Operating permit, alteration
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Heated door lock cylinder 9X0 Without heated door lock cylinder
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Malfunction display 9HA Without additional malfunction display
Moldings 4ZE Black moldings
Nameplate set 2VP Nameplate set "TDI" "I"
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Parking light indicator light 8NA Without parking light warning light
Partition 3CX Net partition
Radios 8AC Radio "beta"
Reading light 8S4 Two reading lights front, two rear
Rear cargo area 3GK Without additional lower part for luggage compartment floor
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Safety certificate 0LA Without special plates/stickers/ safety certificates
Seat covering N0P Woven fabric seat covering
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Ski bag 3X0 Without load-through provision
Special labels/plates 0SB Labels/plates in German
Steering wheels 2PQ Steering wheel for air bag system
Telephone/telematics 9W8 Car phone preparation
Tires H6S Tires 195/65 R15 V
Trailer hitch 1D2 Trailer hitch, removable and lockable
Transmission specifications G0E 4-speed automatic transmission
Transmission types/gearshift mechanisms 0G2 Selector lever
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 0JZ Without determination of weight category for front axle
Wheels C0V Steel wheels 6J x 15
Window regulator 4R2 Power windows front, mechanical window regulators rear
Windshield wiper intermittent control 8N1 Windshield wiper intermittent control
PT2
RBB
Base engine T1R 4-cylinder diesel engine 1.9 L unit 028.R
visitos pisze:proszę o sprawdzenie nr vin WVWZZZ1JZ1W238352
pzdr. Łukasz
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ1W238352
Model GOLF
Date of production 23.08.2000
Model year 2001
Sales type 1J1366
Engine code AJM
Transmission code DRW
Axle drive 6S
Interior trim code RD
Roof color 8E
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Brake type, front 1ZM Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Braking systems 1AT Electronic stabilization program (ESP)
Bumper 2JC Comfort bumpers
Center rear seat belts 3C7 3-point seat belt for center rear seat
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Cruise control 8T2 Cruise control system (CCS) electronic
Doors 0A2 4 doors
Engine specifications M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0
Equipment levels A8F Sports equipment
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor coverings 3MH Dilours floor covering w/o scuff guard
Fuel systems 0F9 Cooled fuel system for diesel engine
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C16 Operating permit, alteration
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Headlight washer system 8X1 Headlight washer system
Headlight-range adjustment 8Q2 Automatic headlight-range adjustment static
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Nameplate set 1DG Nameplate set "TDI"
Protective side molding 4B2 Body-colored protective side molding
Rear headrests 3Q6 Three rear headrests
Rear seats 3NC Rear seat bench/backrest, split folding
Rear stabilizer 0BB Rear stabilizer
Seat covering N2P Fabric seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Service interval prolongation QG2 No possibility of activating service interval prolongation
Shock absorption, chassis, front G72 Front shock absorption
Side air bag 4X3 Side air bag front with curtain air bag
Spare wheel/breakdown set 1G1 Space-saving spare wheel
Steering QZ3 Power steering (limited steering lift mechanism)
Steering wheels 2PX Leather trimmed sports steering wheel
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Tires H6L Tires 225/45 R17 91W
Transmission specifications G0K 6-speed manual transmission
Trunk sill protection 2P0 Without trunk sill protection
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L08 Suspension range 08 installation control only, no requirement forecast
Wheel covers 1NL Covers for alloy wheels
Wheels CD1 Alloy wheels 7J x 17
P07
PH0
PJ6
PTB
PXE
Front seats Q4H Comfort sports seats, front
RCA
Base engine T4N 4-cylinder diesel engine 1.9 L unit 038.A
Shock absorption, chassis, rear UB1 Rear shock absorption for sports design
arri18 pisze:Witam,
Prosze o sprawdeznie VIN
WVWZZZ1JZWW095661
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZWW095661
Model GOLF
Date of production 26.03.1998
Model year 1998
Sales type 1J1244
Engine code AGR
Axle drive 5S
Interior trim code JS
Roof color F8
Exterior color / Paint Code F8 / C7V
Backrest release 3H9 Backrest release for front seats with "Easy Entry"
Brake type, front 1LR Front disc brakes with integrated adapter
Component part sets with country-specific design requirements B0K Component parts set, complying with vehicle type for France, various parts
Control number (no PR-Family) S4Q Plant employee leasing for Poland
Doors 0A1 2 doors
Floor mats 0TQ Front and rear floor mats (polypropylene)
Front fog light/additional headlight 8WD Integrated front fog light
Key for locking system 8QE Key for locking system with remote control
Luggage net/pocket on backrest(s) 4U1 Luggage nets/pockets on backrests
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Seat covering N2N Woven fabric seat covering
Side lights 8F6 Dark colored side turn signal lights
Special labels/plates 0SG Labels/plates in French
Type approval countries/countries with special requirements B08 Type approval France
P16
uprzejmie prosze o sprawdzenie VIN WVWZZZ3BZ2P298199
pozdrawiam
pozdrawiam
Kupie golfa II/JETTA 5D 1.6 lub 1.8 benzyna moze byc LPG. Kontakt na PW/GG 3897209. tel. 501 419 453
magisterska
Witam! Prosze o sprawdzenie Vin: WVWZZZ1KZ5W064771
Z góry dziekuje!
Z góry dziekuje!
- KnightRider1986
Proszę o rozkodowanie Vin:
WVWZZZ1KZ7P050051
Dziękuje
WVWZZZ1KZ7P050051
Dziękuje
Tam gdzie zaczyna się Pruszków, kończą się Reguły.
