Nie daj się oszukać, sprawdź VIN i historię
Chcesz kupić, bądź sprowadzić auto..nie wiesz, które wybrać? Napisz o tym tutaj...
Moderatorzy: palio, jhosef, VIP
luckd
Auto: Octavia
Silnik: BFQ
Nie daj się oszukać, sprawdź VIN i historię /czytaj 1 post/
Post autor: luckd » czw lis 29, 2012 15:46
Nie da się rozkodować tego toledo VSSZZZ1MZ4R122334 ?
BZYCZEK2
Post autor: BZYCZEK2 » czw lis 29, 2012 22:52
Witam.
Czy mógłbym prosić o sprawdzenie tego vinu: TMBHS21Z182209947
Dzięki i pozdrawiam
VIN
Post autor: VIN » pt lis 30, 2012 11:22
Kod: Zaznacz cały
Vehicle Identification No.	WV1ZZZ70Z2X095823
Model Designation	transp. van
Date of production	16.01.2002
Model year	2002
Sales type	7DA1U2
Engine code	AJT
Transmission code	EWB
Axle drive	5S
Interior trim code	BX
Roof color	T7
Exterior color / Paint Code	T7 / 902
Activated carbon canister 	1E0 	Without activated charcoal canister
Additional air-borne noise suppression measures 	1J0 	Without additional sound absorbing measures
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional dust seals 	6U0 	Without additional seals outside
Additional tires (winter tires) 	2WA 	Without additional tires
Additional ventilation system 	7J0 	Without additional ventilation system
Air bag 	4UC 	Air bag for driver
Air cleaner (engine) 	1L0 	Standard air cleaner
Antennas 	8L1 	Bright rod antenna
Anti-theft protection system 	7AA 	Electronic vehicle immobilization device
Antidrum measures 	2N1 	Standard anti-drum measures
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Armrests for front seats 	4S0 	Without armrests for front seats
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Base engine 	T7K 	5-cylinder diesel engine 2.5 L unit 074.5
Batteries 	J0R 	Battery 380 A (80 Ah)
Body style 	K4A 	Panel van
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake type, front 	1LU 	Disc brakes, front
Braking systems 	1AB 	Power brake
Bumper 	2JB 	Standard bumpers
C-rails 	6L0 	Without C-rails
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
CD changer/CD player 	7A0 	Without CD changer/CD player
Carrier frequency for radio remote control 	5D0 	Without carrier frequency
Center high-mounted stop light 	8R0 	Without center high-mounted stop light
Chassis 	2E2 	15-inch chassis
Child lock 	4H0 	W/o child lock in passenger compartment
Climatic zones 	0Y1 	Standard climatic zones
Clutch actuation 	1K2 	Hydraulic clutch actuation
Component part sets with country-specific design requirements 	B0X 	Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 	6FA 	Components without special surface appearance
Compressor 	2AA 	Without compressor or preparation respectively
Control number (no PR-Family) 	S2D 	Control (in-plant)
Cruise control 	8T0 	Without cruise control system (CCS)
Cup holder 	4M0 	Without cup holder
Curtains/roller blinds 	5G0 	Without curtains
Dashboard 	4N2 	Standard dashboard
Delivery equipment 	2A0 	Without delivery equipment
Different vehicle equipment 	5EA 	Without different vehicle equipment
Differential lock 	1Y0 	Without differential lock
Door and lid locking system 	4F0 	Mechanical locking system
Door and side trim panels 	3LN 	Unpainted door trim panel
Door pockets, front 	3YB 	Door pockets, front
Doors, cab 	0D1 	Cab doors
Doors, passenger/load compartment, left 	5Q0 	Without door in load/passenger compartment left (closed side panel)
Doors, passenger/load compartment, right 	5R2 	Sliding door right in load/passenger compartment
Drive layout 	1X0 	Front wheel drive
Emission standard 	0GE 	Emission standard EU3
Engine specifications 	MP2 	5-cylinder diesel engine 2.5 L/65 kW TDI base engine is T7K
Equipment levels 	A8B 	Basic equipment
Exterior mirror setting 	6XA 	Exterior mirrors: adjustable from outside
Final drive/gear ratio 	0ZN 	Transmission ratio, high geared
Floor coverings in cab 	5AC 	Rubber floor covering in cab
Floor coverings in passenger and load compartment 	5BA 	Without floor covering in passenger/load compartment
Folding table 	1U0 	Without table
Fourth row of seats 	3WA 	Without bench seat
Frame forestructure 	AC0 	Short frame forestructure
Fresh air unit/air outlet 	6LD 	Fresh air unit with center outlet and recirculation door, without load/ passenger compartment ventilation
Front Assist 	6K0 	without Front Assist/without city automatic emergency braking
Front fog light/additional headlight 	8WA 	Without front fog light
Front seat, left 	3TH 	Seat in cab, left
Front seat, right 	3SH 	Seat in cab, right
Front side window for load or passenger compartment, left 	4DA 	Without side window aperture in load compartment, front left
Front side window for load or passenger compartment, right 	4EA 	Without side window aperture in load compartment front right
Front stabilizer 	0AB 	Front stabilizer
Front underbody guard 	1SA 	Without additional front underbody guard
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
General operating permit, alterations 	C13 	Operating permit, alteration
Generators 	8GD 	Alternator 90A
Headlight 	8BB 	Halogen headlight for driving on the right
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X0 	Without headlight washer system
Headlight-range adjustment 	8Q1 	Headlight-range adjustment
Headrests 	3J4 	Headrests for front seats
Heated washer nozzles 	9T0 	Without heated washer nozzles
Heating and air conditioning system 	9AA 	Manually controlled heating system
Hinges for side and tail gates 	5V0 	Without hinges for side and tail gates
Hood and trunk stay 	5NC 	Standard tailgate stay
Horns 	8Y0 	Single-tone horn
Hydraulic pump 	2BA 	Without hydraulic pump
Identification lights, roof 	9KA 	Without identification lights
Identification plates 	1EC 	Special identification plate
Insert for the filling up of unleaded fuel/fuel type 	2G0 	Without insert for the filling up of fuel
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
Interference suppression 	8E0 	Without interference suppression
Interior light in driver compartment 	9GA 	Interior light with door pillar switches
Interior lights, passenger and load compartment 	9CC 	Two standard interior lights in passenger/load compartment
Interior noise suppression measures 	3W6 	Additional interior noise suppression
Lashing rings/rails for load restraint 	6B1 	Lashing rings for load restraint
Leather parts scope 	3HA 	Without leather parts scope
Left exterior mirror 	5SL 	Left exterior mirror: aspherical
Left vanity mirror 	4SA 	Without left vanity mirror
Light assistance system 	8G0 	Without light assistant
Lock operation for tailgate/trunk lid 	4E3 	Without tailgate release lever inside
Malfunction display 	9HA 	Without additional malfunction display
Manufacturing sequence differentiation 	0FM 	Poland manufacturing sequence
Mounting fixture for oxygen bottle 	5P0 	W/o mounting fixture for oxygen bottle
Mud flap 	6N0 	Without mud flaps
Multi-function display/trip computer 	9Q0 	Without multi-function display/ on-board computer
Nameplate set 	0NB 	Nameplate set in base trim
Navigation device 	7Q0 	Without navigation device
Owner's manuals 	0VC 	Information kit in German
Paint preservative/transit coating 	5K1 	Paint preservative (wax)
Partition 	3CF 	Partition without window
Payloads 	0J1 	Reduced payload
Pickup bodywork/cargo area 	5HA 	Without pickup bodywork/cargo area
Preparation for identification lights 	9QA 	Without identification light preparation
Radios 	8AA 	Without radio
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear gates/tailgate 	3RB 	Trunk lid without window aperture
Rear headrests 	3Q0 	Without rear headrests
Rear side window for load or passenger compartment, left 	4FA 	W/o side window aperture in load comp. rear left
Rear side window for load or passenger compartment, right 	4JA 	W/o side window aperture in load comp. rear right
Rear stabilizer 	0BA 	Without rear stabilizer
Rear window insert 	4HA 	Without rear window
Rear window wiper and washer system 	8M0 	W/o rear window wiper and washer system
Refrigerator 	1W0 	Without refrigerator/glove compartment cooling system
Restraint systems, front 	3QC 	3-point seat belts, front
Retaining cables for tail and side gates 	5T0 	Without retaining cables for tailgate
Right exterior mirror 	5RQ 	Right exterior mirror: convex
Right vanity mirror 	4TA 	Without right vanity mirror
Roof insert in cab 	3EA 	Without roof insert in cab (closed)
Roof insert in driver's/load compartment 	3JA 	Without roof insert in load and passenger compartment
Roof interior trim 	5CL 	Roof interior trim in cab as comfort molded headlining, in load/passenger compartment with hardboard
Roof turn signal lights 	9H0 	Without roof turn signal lights
Roof types 	3R0 	Standard roof
Seat belt check 	9P0 	Without seat belt reminder
Seat belts for first row of seats passenger compartment 	4PA 	Without seat belts in first row of seats
Seat belts for second row of seats passenger compartment 	4RA 	Without seat belts second row of seats
Seat belts for third row of seats passenger compartment 	4VA 	Without seat belts in third row of seats
Seat covering 	N0A 	Woven fabric seat covering
Seat heater 	4A0 	Without seat heater
Seat storage trays, first row of seats passenger compartment 	4G0 	W/o storage trays, first row of seats
Seat storage trays, second row of seats passenger compartment 	4WA 	W/o storage trays, second row of seats
Seating comfort 	5Y0 	Standard seat padding
Second battery/battery installation 	8FA 	Without second battery
Second generator 	8HA 	Without second alternator or preparation
Second heat exchanger 	6AA 	Without second heat exchanger
Second row of seats 	3UA 	Without seats
Service interval prolongation 	QG1 	Service interval prolongation
Shock absorption/suspension, chassis 	1BA 	Standard suspension/shock absorption
Side interior trim, passenger and load compartment 	5DA 	Side trim panel for basic equipment
Socket 	7B0 	Without socket
Sound combination for rotating emergency light 	9LA 	Without rotating emergency lights
Spare wheel mounts 	1B1 	Standard spare wheel bracket
Spare wheel/breakdown set 	1G2 	Steel spare wheel with original equipment tires
Speaker installation 	8RD 	2 speakers (passive)
Special editions 	E0A 	No special edition
Special labels/plates 	0SB 	Labels/plates in German
Speedometer cable and seal 	8CC 	Speedometer sensor without seal (electronic speedometer sensor)
Stacking panel in load compartment 	3E0 	W/o stacking panel in load compartment
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	2PG 	Steering wheel
Step illumination 	9N0 	Without step illumination
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Stowage box 	3Z0 	Without stowage box
Strip and films all-around 	5M0 	Without warning strip and films
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
Suspension, chassis 	1P0 	Standard suspension
Tachograph/logbook 	9NA 	Without tachograph
Tail and side gates 	5S0 	Without tail and side gate(s)
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Third row of seats 	3VA 	Without seats
Tire suppliers 	V0A 	Tires w/o specification of tire brand
Tires 	H0Y 	Tires 165/65 R15 81T reduced rolling resistance
Tool kit and jack 	1S1 	Tool kit and jack
Top frame and tarpaulin 	5GA 	Without pickup bodywork/tarpaulin
Trailer hitch 	1D0 	Without trailer hitch
Transmission specifications 	G0C 	5-speed manual transmission
Transmission types/gearshift mechanisms 	0G1 	Gearshift lever
Tray areas, cab 	5FF 	Console under dashboard, center
Type approval countries/countries with special requirements 	B01 	Type approval Germany
Underseal 	5U0 	Standard underseal
Vehicle class differentiation units/platform components 	0CN 	Vehicle class differentiation 7D0
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Versions 	FM0 	Basic equipment variant
Wheel covers 	1NE 	Wheel center cover
Wheelbases 	0E1 	Short wheelbase
Wheels 	C7X 	Alloy wheels
Window regulator 	4R0 	Mechanical window regulator
Windows, cab 	4CC 	Cab side window in heat-insulating glass
Windshield glass type 	4GF 	Windshield in heat-insulating glass
 	Z36
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1KZ8M280412
Model Designation	golf estate
Date of production	08.05.2008
Model year	2008
Sales type	1K5121
Engine code	BLS
Transmission code	JCR
Axle drive	5S
Interior trim code	KU
Roof color	2R
Exterior color / Paint Code	2R / D7X
"Multimedia", video/DVD/notebook connection 	9WC 	Without "Multimedia" in vehicle
Additional body covers, side 	6EA 	Without additional side body covers (stone guard)
Additional child seat anchors 	3B4 	Child seat anchor for child seat system ISOFIX
Additional tires (winter tires) 	7DD 	Winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 47 with full wheel cover
Additional warning lights 	9TC 	Additional reflectors (door area)
Air bag 	4UF 	Driver's and front passenger air bag with front passenger air bag deactivation
Antennas 	8ZN 	Antenna
Backrest release 	3H2 	Backrest release for right front seat
Batteries 	J0L 	Battery 340 A (70 Ah)
Battery/alternator capacity 	NY0 	Standard battery/alternator capacity
Body measures 	5C0 	Without special body measures
Body style 	K8D 	Station Wagon Variant/Avant
Brake pad wear indicator 	9U1 	Brake pad wear indicator
Brake type, front 	1ZM 	Disc brakes, front (Geomet D)
Brake type, rear 	1KF 	Disc brakes, rear
Braking systems 	1AT 	Electronic stabilization program (ESP)
Breakaway interior mirror 	4L6 	Breakaway interior rear view mirror, automatically dimming
Bumper 	2JC 	Comfort bumpers
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Center armrest 	6E3 	Front center armrest
Center rear seat belts 	3C7 	3-point seat belt for center rear seat
Child seat anchor, front 	3G0 	Without child seat anchor front (ISOFIX)
Component part sets with country-specific design requirements 	B0A 	Component parts set without country-specific design requirement
Components with special surface appearance 	6FF 	Body-colored exterior mirror housings and various add-on parts
Cruise control 	8T2 	Cruise control system (CCS) electronic
Customized installation 	FC0 	Without customized installation
Delivery equipment 	2A8 	Delivery equipment for shipment
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	4AF 	Door and side trim panel in foam film and woven fabric
Door pockets, front 	3YR 	Door pockets with insert mats
Doors 	0A2 	4 doors
Emission standard 	7GG 	Emission standard EU4 DPF
Engine cooling system 	8Z5 	Not hot country
Engine specifications 	D3W 	4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
Equipment levels 	A8C 	Comfort equipment
Exhaust tailpipe 	0P0 	Rear exhaust tailpipe (standard)
Exterior mirror setting 	6XG 	Exterior mirrors: with memory function, electrically adjustable/heated
Fire extinguisher 	6A0 	Without fire extinguisher
First aid kit / warning triangle 	1T2 	Warning triangle
Floor mats 	0TD 	Front and rear floor mats
Front license plate carrier 	6W1 	License plate carrier front (large)
Front seat, left 	3TF 	Comfort seat, front left
Front seat, right 	3SF 	Comfort seat, front right
Front stabilizer 	0AH 	Front stabilizer
Fuel systems 	0F8 	Cooled fuel system for diesel engine
Fuel tank treatment 	2LD 	Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 	6Q2 	Leather gearshift knob/handle
General operating permit, alterations 	C12 	Operating permit, alteration
Generators 	8GU 	Alternator 140 A
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8BG 	Twin-headlight for driving on the right, with integrated high beam
Headlight activation 	8K8 	Low beam assistant with "Coming Home" function
Headlight washer system 	8X1 	Headlight washer system
Headrests 	3J1 	Height-adjustable headrests for front seats
Heat accumulator system/additional heater 	7E6 	Electric auxiliary air heater
Heated washer nozzles 	9T1 	Heated washer nozzles, front
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Horns 	8Y1 	Two-tone horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 	2G5 	Filler neck module 1 without insert
Inserts 	5MA 	Decorative inserts
Installation differentiation for vehicle components 	0EJ 	Installation differentiation for transmission MQ 250 vehicle components
Interior light in foot area 	6T1 	Interior light in footwell
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 	1PA 	Standard wheel bolts
Luggage compartment cover 	3U6 	Luggage net
Luggage compartment lining 	5A2 	Comfort trunk lining
Luggage net/pocket on backrest(s) 	4U5 	Luggage pockets on backrest
Lumbar support 	7P4 	Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 	0FL 	Mexico manufacturing sequence
Mass damper for steering wheels 	1Q0 	Without mass damper for steering wheel
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	0NA 	Without nameplate set (without model designation)
Operating voltage 	9Z0 	Operating voltage 12V
Outer rear seat belts 	3ZB 	3-point seat belts, outer rear with ECE label
Paint coating 	FB0 	Standard paint coating
Paint preservative/transit coating 	5K5 	Transit coating film with additional transport protection measures
Park distance control 	7X1 	Park distance control
Partition 	3CX 	Net partition
Platform group class 	7PA 	Platform group class 1
Platform module floor pan, rear 	4P3 	Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Protective side molding 	4B0 	Without protective side molding
Radios 	8AG 	Radio with CD/MP3
Reading light 	8S4 	Two reading lights front, two rear
Rear cargo area 	3GD 	Plane rear cargo area
Rear headrests 	3T2 	Three rear headrests
Rear license plate carrier 	6P1 	License plate carrier rear (ECE)
Rear seats 	3NW 	Rear seat bench/backrest, split folding with center armrest
Rear spoiler 	5J0 	Without rear spoiler
Rear stabilizer 	0BG 	Rear stabilizer
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Refrigerator 	1W2 	Glove compartment cooling system
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Roof insert/convertible top 	3FA 	Without roof insert (standard roof)
Roof rails/roof load rack 	3S2 	Black roof rails
Rough-road/sports version 	2UA 	Standard design
Safety headrest system 	3K0 	Without safety headrest system
Scuff plates 	7M5 	Without protective film for scuff plate
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat belt check 	9P3 	Seat belt reminder, electric contact in buckle
Seat covering 	N3L 	Circular-knit cut pile seat covering
Seat heater 	4A3 	Seat heater for front seats separately controlled
Shock absorption, chassis, front 	G67 	Front shock absorption
Shock absorption, chassis, rear 	1JA 	Rear shock absorption, basic design 1
Side air bag 	4X3 	Side air bag front with curtain air bag
Side and rear windows 	4KF 	Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
Side lights 	7R3 	Side turn signal lights (white)
Ski bag 	3X0 	Without load-through provision
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Socket 	7B2 	12-volt socket in luggage boot
Speaker installation 	8RM 	8 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special labels/plates 	2KW 	Labels/plates in German, French, and Dutch
Special registration measures 	3M0 	Without special measures
Steering 	1N3 	Speed-related variable steering assist (Servotronic)
Steering wheels 	1MH 	Leather steering wheel
Tire pressure warning light 	7K6 	Flat tire indicator
Tires 	HH7 	Tires 205/55 R16 91V
Trunk sill protection 	2P1 	Plastic trunk sill protection
Upgrading measures 	GP0 	Vehicles w/o special upgrade measures
Vehicle class differentiation units/platform components 	0HM 	Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
Washer fluid level indicator 	8W1 	Washer fluid level indicator
Weight category front axle 	L07 	Suspension range 07 installation control only, no requirement forecast
Weight category rear axle 	0YG 	Weight range 7 installation control only, no requirement forecast
Wheel covers 	1NY 	Full wheel covers
Wheels 	CM1 	Steel wheels 6.5J x 16
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield wiper intermittent control/ light/rain sensor 	8N3 	Windshield wiper intermittent control with rain sensor
 	P15
 	PH2
 	PME
Child seats 	QA0 	Without child seat
Chrome work package 	QJ1 	Chrome work package
Compass/traffic sign display 	QR0 	Without compass/traffic sign display/ traffic signs recognition
Drawers under front seats 	QN3 	Drawers under front seats
Electronic map cooling system 	QS0 	Without electronic map cooling system
Nameplates for sales name 	QD0 	Without lettering for sales name
TV reception/digital radio reception 	QV0 	W/o TV reception/digital radio reception
 	RCL
Air duct, front area 	VK0 	Air duct, standard
Base engine 	TG0 	4-cylinder diesel engine 1.9 L unit 03G.6
Electric interface for external use 	UF0 	Without electric interface
Hill hold control 	UG0 	Without hill hold control / hill descent control / comfort driving assist
Instrument inserts 	U5A 	Instrument insert, km/h speedometer
Marten repeller 	UM0 	Without marten repeller
Pedal cluster 	VF0 	Standard pedal cluster
Pedestrian protection 	VL0 	Standard pedestrian protection measures
Remote-controlled garage door opener 	VC0 	W/o remote-controlled garage door opener
 	WW1
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ7MZ5V018409
Model Designation	sharan
Date of production	18.11.2004
Model year	2005
Sales type	7M63C3
Engine code	ASZ
Transmission code	FUX
Axle drive	6S
Interior trim code	JV
Roof color	8E
Exterior color / Paint Code	8E / A7W
Anti-theft protection system 	9V7 	Electronic vehicle immobilization device with anti-theft alarm system and passenger compartment control
Auxiliary heating 	9M5 	Auxiliary heater
Body style 	K8P 	MPV
Bumper 	2JG 	Body-colored bumpers
CD ROM/DVD/SD card 	7QB 	CD ROM (Germany)
Center armrest rear 	6D7 	With rear armrests
Controls (steering wheels/steering column) 	4LA 	Without controls
Door and lid locking system 	4K1 	Radio remote controlled central locking
Door and side trim panels 	4AB 	Door and side trim panel partially in leather
Electric safety package 	9BC 	Display and warning tone f. opened doors
Engine specifications 	D3E 	4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels 	A8T 	Executive equipment
Exterior mirror setting 	6XE 	Exterior mirrors: electrically foldable and electrically adjustable/heated
First aid kit / warning triangle 	1T0 	Without first aid kit and warning triangle
Floor coverings 	3MG 	Tufted fine cut pile floor covering
Floor mats 	0TL 	Front and rear floor mats (leatherette binding)
Front fog light/additional headlight 	8WD 	Integrated front fog light
Fuel systems 	0F3 	Fuel system for diesel engine
General operating permit, alterations 	C26 	Operating permit, alteration
Generators 	8GL 	Alternator 120 A
Headlight activation 	9C0 	Without special headlight activation mode but with "Coming and Leaving Home" feature
Heating and air conditioning system 	9AH 	Climatronic with second evaporator and second heating system
Insert for the filling up of unleaded fuel/fuel type 	2G9 	Filler neck module 2 with insert
Inserts 	5TF 	Decorative wood inserts
Interior lighting 	9ME 	Comfort interior lighting
Leather parts scope 	3HG 	Leather parts scope
Lockable wheel bolts 	1PB 	Lockable wheel bolts
Luggage compartment cover 	3U4 	Luggage compartment cover
Luggage net/pocket on backrest(s) 	4U0 	Without luggage nets/pockets on backrests
Marque-specific/class-specific features 	0Z0 	VW marque-specific/class-specific features
Navigation device 	7Q2 	Navigation system with color screen
Protective side molding 	4B1 	Protective side molding
Radios 	8AY 	Radio/navigation system
Roof rails/roof load rack 	3S1 	Bright roof rails
Seat covering 	N7K 	Alcantara/leather seat covering
Second row of seats 	3UL 	2 sports seats
Side air bag 	4X1 	Side air bag front
Side and rear windows 	4KH 	Green tinted side windows, from B-pillar and rear window laminated glass w/ metal layer, man. oper. hinged quarter window
Speaker installation 	8RX 	Passive speakers
Steering wheels 	1MR 	Leather steering wheel
Sun visors 	5XC 	Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
Swiveling front seats 	3A0 	Without swiveling front seats
Third row of seats 	3VP 	2 sports seats
Tires 	H1V 	Tires 225/45 R17
Top carrier 	NG0 	Without top carrier
Transmission specifications 	G0M 	6-speed manual transmission top speed in fifth gear
Upgrading measures 	GP1 	Vehicles with special upgrade measures
Vehicle class differentiation units/platform components 	0DQ 	Installation differentiation for build status of vehicle class B (MPV) unit components
Wheels 	CX8 	Alloy wheels 7J x 17
Window regulator 	4R3 	Power windows with comfort operation
Windshield glass type 	4GX 	Windshield in heat-insulating glass, heated
Windshield wiper intermittent control/ light/rain sensor 	8N2 	Windshield wiper intermittent control infinitely variable
 	PH5
 	PI1
 	PJ7
 	PW2
Front seats 	Q1D 	Sports front seats
Tray areas package 	QE0 	Without tray areas package/box
 	RHA
Control number (no PR-Family) 	SZ9 	Delivery by "Autostadt Wolfsburg"
Instrument inserts 	U3M 	Instrument insert with tachometer trip-odometer, km/h speedometer
 	WT1
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
VIN
Kod: Zaznacz cały
Vehicle Identification No.	TMBHS21Z182209947
Model Designation	octavia comb.ambiente
Date of production	24.07.2008
Model year	2008
Sales type	1Z5264
Engine code	BXE
Axle drive	5S
Interior trim code	BK
Roof color	1Z
Exterior color / Paint Code	1Z / F9R
"Charism" 	2H0 	Without "drive select"
"Multimedia", video/DVD/notebook connection 	9WR 	Installation of audio connection
Adapter (for trailer hitch) 	ND0 	Without adapter
Additional warning lights 	9TB 	Additional warning lights (door area)
Antennas 	8L3 	Roof antenna
Backrest release 	3H0 	Without backrest release for front seats
Batteries 	J0N 	Battery 330 A (61 Ah)
Brake type, front 	1ZF 	Disc brakes, front (Geomet D)
Brake type, rear 	1KD 	Disc brakes, rear
Braking systems 	1AC 	Anti-lock brake system (ABS)
Breakaway interior mirror 	4L2 	Dipping breakaway interior rear view mirror
Breakdown spray 	GR0 	Without emergency tire inflator
Component part sets with country-specific design requirements 	B1M 	Component parts set for Czech Republic
Components with special surface appearance 	6FB 	Body-colored exterior mirror housings
Cruise control warning and speed limit system 	6Y0 	Without cruise control warning system
Dashboard 	4N1 	Padded dashboard
Dashboard illumination 	7V0 	Standard dashboard illumination
Door and side trim panels 	3LT 	Door and side trim panel
Doors 	0A2 	4 doors
Doors/trays in trunk 	3N2 	Stowage box with cover in luggage boot side panel
Emission standard 	0GG 	Emission standard EU4
Exterior mirror setting 	6XN 	Exterior mirrors: electrically adjustable, separately heated
Floor mats 	0TA 	Without floor mats
Front fog light/additional headlight 	8WB 	Front fog lights
Front seat, left 	3TB 	Standard seat, front left
Front seat, right 	3SB 	Standard seat, front right
Front stabilizer 	0AE 	Front stabilizer
Fuel filler cap/door, locking option 	2W3 	Fuel filler cap remote unlocking
Fuel quantity for initial filling 	1Z2 	Increase in initial standard fuel filling
Gearshift knob/handle 	6Q4 	Comfort gearshift knob/handle
General operating permit, alterations 	C00 	Operating permit, initial registration
Glove compartment 	4Z5 	Glove compartment door with light
Hand brake lever handle 	6PA 	Plastic hand brake lever handle
Headlight 	8JM 	Twin headlight for driving on the right, with integrated high beam
Headrests 	3J7 	Articulated and height-adjustable headrests for front seats
Heating and air conditioning system 	9AP 	Climatic air-conditioning system (semi-automatic)
Hood and trunk stay 	5NA 	Hood stay
Inserts 	5MD 	Decorative aluminum inserts
Interior light in driver compartment 	9GG 	Two interior lights with door pillar switches
Interior light in foot area 	6T0 	Without interior light in footwell
Key for locking system 	8QL 	Key for locking system with remote control
Left vanity mirror 	4SB 	Vanity mirror left
Luggage compartment cover 	3U2 	Sliding trunk cover
Luggage compartment floor covering 	6SA 	Without trunk floor covering
Luggage compartment lighting 	9E3 	Luggage compartment lighting
Manufacturing sequence differentiation 	0FA 	Standard manufacturing sequence
Nameplate set 	1RX 	Nameplate set in base trim
Outdoor temperature gage 	9Y1 	Outdoor temperature gage
Owner's manuals 	0VT 	Information kit in Polish
Paint preservative/transit coating 	5K7 	Transport protection film (minimum protection) with additional transport protection measures
Parking light indicator light 	8NB 	Parking light indicator light
Partition 	3CA 	Without partition
Platform group class 	7PB 	Platform group class 2
Radios 	8YH 	Radio, version 1
Reading light 	8S5 	Two reading lights front
Rear cargo area 	3GA 	Without cargo area
Rear headrests 	3Q6 	Three rear headrests
Rear stabilizer 	0BD 	Rear stabilizer
Right vanity mirror 	4TB 	Vanity mirror right
Safety certificate 	0LA 	Without special plates/stickers/ safety certificates
Seat belt check 	9P1 	Seat belt reminder, electric contact in buckle
Seat covering 	N2M 	Fabric seat covering
Shock absorption, chassis, front 	G02 	Front shock absorption
Side and rear windows 	4KC 	Side and rear windows in heat-insulating glass
Side lights 	7R6 	Side turn signal lights in exterior mirrors
Smoking/non-smoking package 	9JD 	Smoking package, ashtray front
Speaker installation 	8RE 	4 speakers (passive)
Special labels/plates 	2KE 	Labels/plates in Czech and Slovakian
Steering wheels 	1MA 	Steering wheel
Tie down straps/net/pocket 	6M5 	Trunk net
Tire pressure warning light 	7K0 	Without tire pressure warning light
Tires 	H7F 	Tires 195/65 R15 91H
Tray 	7N0 	Without tray on roof liner
Type approval countries/countries with special requirements 	B17 	Type approval Poland
Vehicle class differentiation units/platform components 	0HF 	Vehicle class differentiation 1Z0
Vehicle type 	AZ0 	Vehicle with standard production scope
Washer fluid level indicator 	8W0 	Without washer fluid level indicator
Weight category front axle 	L06 	Suspension range 06 installation control only, no requirement forecast
Weight category rear axle 	0YF 	Weight range 6 installation control only, no requirement forecast
Wheel covers 	1NN 	Full wheel covers
Wheels 	C8V 	Steel wheels 6J x 15
Windshield wiper intermittent control/ light/rain sensor 	8N4 	Windshield wiper intermittent control with potentiometer (four speeds)
 	PDC
 	PG0
 	PH4
Chrome work package 	QJ3 	Chrome package (type 2)
Drawers under front seats 	QN2 	Drawer under right front seat
Tray areas package 	QE4 	Tray areas package 2
 	RAB
Base engine 	T71 	4-cylinder diesel engine 1.9 L unit 03G.1
Instrument inserts 	U4A 	Instrument insert, km/h speedometer
VIN
Re: Nie daj się oszukać, sprawdź VIN i historię /czytaj 1 po
Post autor: VIN » pt lis 30, 2012 11:23
luckd pisze:Nie da się rozkodować tego toledo VSSZZZ1MZ4R122334 ?
Niestety nie.
Jedrzej83
Post autor: Jedrzej83 » pt lis 30, 2012 17:06
Czy mogę prosić o rozkodowanie tego VINu: WVWZZZ1KZ6W015005
Dziękuję i pozdrawiam wszystkich :)
Matfix
Post autor: Matfix » sob gru 01, 2012 00:54
Prosiłbym o rozkodowanie VIN : WVWZZZ1HZSP079097
Z góry dziękuje :)
Dawid3103
Post autor: Dawid3103 » sob gru 01, 2012 09:58
Witam prosił bym o rozkodowanie VIN : WVWZZZ1JZYW739497
kiler.
Post autor: kiler. » ndz gru 02, 2012 12:44
Witam :D
Bardzo proszę o sprawdzenie poniższych VIN (zależy mi też pod stopniem serwisowania czy przebiegi km są wiarygodne)
TMBJC26Y743964538
TMBWU46Y243892405
WVWZZZ1JZ2D203367
WVWZZZ3BZ2P187455
Odpowiedz prosze przesłać na pw
Z góry wielkie dzięki :-)
beler
Post autor: beler » pn gru 03, 2012 21:22
siema
proszę o sprawdzenie tego vinu
WVWZZZ6EZ3W001873
pozdrawiam :crazy:
nowy13
Post autor: nowy13 » wt gru 04, 2012 14:10
Zakupiony nabytek :)
Poproszę jeszcze tego:
WVGZZZ1TZ6W206064
Croix
Post autor: Croix » wt gru 04, 2012 22:26
Witam ponoVWnie,
Panie i Panowie mam prośbę jako długo i wielo letni posiadacz aut marki VW (teraz znowu powrót do Golfa :P) prosiłbym o rozkodowanie tego numeru VIN - WVWZZZ1JZXD129647
z góry dziękuje.
[url=http://www.fotosik.pl][img]http://images27.fotosik.pl/138/3791d8d257bf8b24.jpg[/img][/url]
Ciesiełko
Post autor: Ciesiełko » wt gru 04, 2012 22:37
Witam można sprawdzic numer identyfikacji :)
Golf mkI
1793378320
Jest MKI
http://forum.vwgolf.pl/viewtopic.php?f=86&t=486325" onclick="window.open(this.href);return false;
Robi się drugie MKI
http://forum.vwgolf.pl/viewtopic.php?f=86&t=577885" onclick="window.open(this.href);return false;
Był MkIII
http://forum.vwgolf.pl/viewtopic.php?f=88&t=451235" onclick="window.open(this.href);return false;
187
Post autor: 187 » śr gru 05, 2012 17:16
Witam,
prosilbym o rozkodowanie ponizszego numeru VIN>
WVWZZZ1JZ3W308675
Golf 4 1.9 tdi
2003
stan licznika: ok. 199 tys.
Z gory dziekuje za pomoc. Prosilbym o info na PW.
Wróć do „Chcę kupić auto”
